Author Topic: Help identify my usb connector on my laptop so i can buy a replacement  (Read 507 times)
Offline spaceship9876Topic starter
I have attached some photos of a usb3 port that i need a replacement of. Some of a usb cable connector have become stuck inside the port so i want to order a new port to solder on my laptop pcb.
Thanks  :D
CCM is stamped on the connector, i assume that is the manufacturer. The code C1628 or C1620 is printed on the connector too. I tried googling the code and stamp to no avail. I think the code is the date of manufacture.
« Last Edit: November 12, 2023, 07:07:23 pm by spaceship9876 »
Offline madires
  • A qualified hobbyist ;)
Re: Help identify my usb connector on my laptop so i can buy a replacement
« Reply #1 on: November 12, 2023, 06:15:14 pm »
Finding the exact connector model could be very hard. I'd look for a connector with the same dimensions, pin layout and mounting tabs. Or you could  buy a set with 10 or more common connector models if you need to replace USB connectors from time to time.
« Reply #2 on: November 12, 2023, 07:41:50 pm »
update: found one by entering my laptop model and "usb connector" on aliexpress.
Online wraper
  • Country: lv
« Reply #3 on: November 12, 2023, 08:06:19 pm »
Measure actual dimensions. Similar look can be misleading, such connectors come in different mounting depth variants (will fit on PCB but not enclosure) and mounting tab locations can be slightly different too. Also be aware to not buy connector that is rotated by 180o internally.
