I switched on my unit with a load on the output. Input voltage was 50V, output set to 5V, load was appr. 3 amps.
I do not know what went wrong, but the U1 with 6 pins marked in the picture burned. Since then it always outputs the input voltage.
Can someone tell me the ID of this component? Thank you.
