22=22uFC=16V
What a pile of disinfo First of all, assuming it's a Nichicon product in the first place, it's CM series so here's the correct datasheet http://nichicon-us.com/english/products/pdfs/e-cm.pdfAnd, under this assumption, the voltage code is H and therefore 50V.
Well, you have the CM datasheet, so go and check if a part like yours exists in this series.If it doesn't, keep searching. If it does, well, at least you have one possible candidate
