Author Topic: help identify smd component  (Read 1837 times)
Offline DaxxinTopic starter
« on: August 15, 2015, 09:54:32 am »
what rf transistor this , separating the output from circuit i get 3,1 ohm between this pin and gnd ..thats regular?
Offline andybarrett1
Re: help identify smd component
« Reply #1 on: August 15, 2015, 11:02:21 am »
Looks like a MAR6 or MAR8 type device...
Can you tell us a bit more about the CCT.
BR
Andy
« Reply #2 on: August 15, 2015, 11:50:58 am »
thanks for reply , this is IF AMP / LPF stage of anritsu spectrum analyzer , have no output from this stage
Offline MagicSmoker
« Reply #3 on: August 15, 2015, 12:24:13 pm »
It's not a MiniCircuits MMIC because the input and output traces are reversed (MiniCircuits marks the input with a dot). The most likely candidate I can come up with is a GaAs RF MOSFET, part # ATF-10736. In any event, the resistance between that pin and ground should not be so low.
That said, cutting through the input trace to make that resistance measurement was a bad move, as the trace is designed to act as an impedance matching network at high frequencies (>1GHz). Thus you can expect degraded performance (higher noise floor, more spurs, etc.) even if replacing this part solves the problem.
« Reply #4 on: August 15, 2015, 01:18:59 pm »
thank you for answer i think is that the component ..alredy ordered.  :-+
