Hello,
Have at hands a Harman Kardon SMPS usb adapter with 3 usb output at 5V, 5A. Model number 5v-5c-5u.
The power supply is totally dead. No blown fuse. Everything on as well secondary as primary sides seems fine, all caps checked with ESR spot on, every through hole (TH) component and SMD are good. Left to be checked is the controller ic which I can't find any info about.
And no, no cold joint, went over every single weld with leaded solder just to be sure.
The IC is a SOT23-6 package with two markings
73E48a
.762a
Any ideas or info about the ic would be appreciated.
BR
