Hi. I have a Proskit SS-989B rework station. The hot air handle was old and broken so I replaced it with the Proskit handle model 9SS-900NB-HG which is supposedly for a different model. Problem is they are a bit different in regard to resistance of the heating element, and I need to calibrate the station.
Calibraion is done by two potentiometers, RH1 and RH2.
When I tweak RH1 is changes actual temperature of the air, RH2 changes also the temperature but by a lower margin per turn than RH1.
Question is, what is the purpose of RH2?
