Author Topic: Help identify this ic  (Read 5397 times)
Offline abdolahTopic starter
  • Country: eg
« on: February 05, 2024, 04:31:34 pm »
a74j01 is an ic in PSU
The PSU MODEL IS : evga supernova nex650g
I CAN'T find the service manual or schematic for it
Leg number 5 & 6 are shorted internally in the ic it makes the PSU
START on it's own not waiting for the pson signal to come
Offline CDaniel
Re: Help identify this ic
« Reply #1 on: February 05, 2024, 08:08:23 pm »
https://www.fsp-group.com/en/knowledge-wpr-22.html#thirteen
More than this I can't find , 6601 is basically the code
The following users thanked this post: abdolah
Online magic
« Reply #2 on: February 05, 2024, 08:22:28 pm »
I have no idea where I found this...
As you see, it's a synchronous rectification controller for 12V/5V output forward topology with added regulated 3.3V buck controller.
No pin numbers, sorry, you will have to figure it out from the PCB.
Offline fzabkar
« Reply #3 on: February 05, 2024, 09:26:30 pm »
« Last Edit: February 05, 2024, 09:53:30 pm by fzabkar »
  • Country: eg
« Reply #4 on: February 06, 2024, 12:34:50 am »
Ok thanks I will try to reverse engineering it .
  • Country: eg
« Reply #5 on: February 06, 2024, 12:37:39 am »
Yeah that help a lot actually thanks
  • Country: eg
« Reply #6 on: February 06, 2024, 01:27:57 am »
Thanks so much for your help .
