Electronics => Repair => Topic started by: ARF on June 25, 2024, 01:04:19 pm
Title: Help identify TSSOP-8 chip
Post by: ARF on June 25, 2024, 01:04:19 pm
Hi guys,
I'm repairing NEC thermal camera TVS-8502.
The one of tantalum capacitors is shorted, and the chip in TSSOP-8 case is damaged on the rail with this capacitor.
The case is damaged, but the board has the same ICs.
The chip has Siliconix like mark. Top marking is "543A".  ~1995 production year
Pinout:
1 Power rail 1 +
2 GND
3 GND
4 ??
5 ??
6 Power rail 2 +
7 Power rail 2 +
8 Power rail 1 +
dual FET?
FOUND: Si6543DQ
Title: Re: Help identify TSSOP-8 chip
Post by: fzabkar on June 25, 2024, 04:23:12 pm
Si6543DQ, Vishay/Siliconix, Dual N- and P-Channel 30-V (D-S) MOSFET, TSSOP-8:
https://web.archive.org/web/20010620082030/http://www.vishay.com/docs/70181.pdf (https://web.archive.org/web/20010620082030/http://www.vishay.com/docs/70181.pdf)
Si6954ADQ, Vishay/Siliconix, Dual N-ch MOSFET, 53mOhm @ 3.4A, 10V, 30V, TSSOP-8:
https://www.vishay.com/docs/71130/71130.pdf (https://www.vishay.com/docs/71130/71130.pdf)
Si6954DQ
http://www.mouser.com/ds/2/427/70179-279753.pdf (http://www.mouser.com/ds/2/427/70179-279753.pdf)
