Author Topic: HP 6034A Power Supply OTP failure  (Read 644 times)
Offline GeneralquarkTopic starter
« on: July 05, 2020, 12:40:19 am »
 I just started working on an older 6034A Power Supply. The self test lights for about .5 seconds then the OTP and SEQ lights come on. It looks like according to the manual
https://literature.cdn.keysight.com/litweb/pdf/06034-90006.pdf?id=800613
There is a temp sensor on the FET heatsink. There does not to be a direct short on the FET from what I can measure.
Just checking if anyone has any experience or tips on this failure before I start reinventing the wheel. I didn't see any past comments on this type of fail in the past on the board.
Thanks!
