The letter code following the part number on all japanise transistors is the gain group. It makes matching transistors in audio equipment easy (just by looking). An A with no space after the part number is a part revision, not a gain group which would have a space after the A most will be like Q, R, S and T. I do not remember the hfe these equeate to, it may be different for different transistors. I have never seen a 2SC1383 in a TO-92 case style.
Jeff
