Author Topic: Help identifying a power connector  (Read 712 times)
Offline pceeTopic starter
« on: September 24, 2021, 06:51:21 pm »
Thanks to everyone last time who helped me identify an unknown component.  Now I'm back with a power connector!
It's 10-pin, and by my measurements 26mm wide by 4mm high, 2.5mm conductor pitch (possibly 2.54mm?).  It looks like a molex of some form, but I got lost in the expanse of their offerings.  See the image below.
Edit: it also has "TYU" in tiny letters along the bottom.
Any leads?
Online DaJMasta
    • medpants.com
Re: Help identifying a power connector
« Reply #1 on: September 24, 2021, 08:35:36 pm »
Googling TYU connector brings you to Tarng Yu Enterprise's webpage which has a product listing.  For crimp connectors in 2.54mm or 2.5mm I don't see an obvious match, but maybe they're solder connections or whatnot.
Are you trying to replace it?  Need a mating connector?  If it's the latter, a regular old male 2.54mm header would probably do even if it isn't keyed or locking.
Offline TimFox
« Reply #2 on: September 24, 2021, 08:43:45 pm »
With ten pins in a row, you should be able to discern the difference between 2.5 mm pitch (22.5 mm total) and 2.54 mm pitch (22.86 mm total) using a calipers.  It is certainly enough to make mating the wrong connectors an unnatural act.
« Reply #3 on: September 24, 2021, 09:39:55 pm »
Good call, it's definitely 2.5mm pitch.
I'm looking for replacement parts both for this connector and the mating connector.
Offline tooki
« Reply #4 on: September 25, 2021, 02:26:51 pm »
It’s Molex Mini-SPOX or a clone thereof.
