Oh the joys when things are too small to put adequate identifying markings on them!
Unfortunately, searching for C017 doesn't provide any useful hits, so this is probably a production or lot code.
The package is 2mm x 2mm x ~0.8mm high. The pin layout appears to be 3 along the top and bottom, and 2 along each side, for a total of 10 pins. The large rectangle toward the bottom right corner is polished and glossy, which is why I suspect it's a sensor. I was also able to identify SCL and SDA lines, so I know it uses I2C.
So far I've tried searching for QFN10 2x2 sensors, but the Si114x/Si115x sensors have 4 pins on top and bottom with 1 on the sides, rather than the above arrangement. Is there a package designation that applies only to the 3+3+2+2 arrangement?
Any other ideas for how I could chase this down?
