Man, you guys rock!! Thank you all for your input, it's very much appreciated
I never would have guessed Bourns since the logo looks like a combination of a capital B and P. The only Bourns logo I'm familiar with is the one they use on their pots. That gives me a good starting point.
I found the power requirements are 15vdc @ 3 amps. On the back side of the board are some terminals for quick disconnects. Presumably some of the MOSFET's on this board are powering some higher current stuff. I'm doing this all by remote control since the CMM is at another plant so I'm unable to see what else may connect to this board.
I know less than nothing about spec'ing TVS diodes. I suspect there's probably a lot more to it than simply I/R ratings, likely in the time domain, but I'm not sure. I'll sniff around Bourns and see if I can narrow things down.
Regarding the inductors, I understand that they're there for noise suppression, just not sure of what value to stick in. I know I can simply bridge them but considering the welding environment this unit is operating in (I'm guessing huge amounts of broad spectrum garbage - aka spark gap transmitters) I'm thinking it would be prudent to replace them with something. I'm just don't know what value of something would be appropriate.
Is 'L8' (the square white component) in the failure path ? If so, it could be damaged/degraded by the overload....
L8 is indeed in the path, just before the TVS. My guess was that it's a common mode choke so I simply checked it for continuity thru each leg and that was OK. I've already removed the TVS to confirm that it was the cause of the short and it was. I now measure about 100k across the power rail initially, but that climbs up as the caps charge.
...Can you provide the details written on the IC adjacent to 'L8' titled 'M5'. MOSFET switch ?
There are a bunch of them on the board. I've attached a close-up of the best pic I have of it. The top line is 4825D, the second an S with a diagonal slash thru it, AA, then a Delta (open Triangle), bottom line is W05C. I didn't find anything online about this puppy either. I don't know of any easy way to check them so I simply checked the resistance across the source and drains and didn't find any that appeared to be shorted.
Got it.
The transorb is a probably a SMAJ15CA (Part labeling is UM).
I would fit SMT fuses or low value fusible resistors in place of those inductors, but that is just me.
I think you are right Dan, I'll take a look at it but considering it's a 15v supply that would sound correct
. Regarding fusing, I have every intention on doing just that. It really pisses me off when manufacturers intentionally design products to fail catastrophically so they can sell you replacements at big $$$$
. Absolutely no excuse for not incorporating some sort of fuseable element - oh wait, silly me, they designed in inductors
I've already pulled the TVS and soldered a couple of pieces of fusable link wire (that was a lot of fun) in place of the 2 inductors. I keep a Kikusui PAL 35-10 here at work. It's not the best for low current work but good enough for a quick test. I powered up the board and it's only drawing 3mA @ 15v. There is a spot on the board marked 3.3v and I had nothing there but I suspect that likely comes from the main board via the large board to board connector. I've attached a picture of the entire board (I didn't have space on the 1st post nor the time to write a second). Since the board has passed the power-up test I'll send it back to the other plant and have them reinstall it for a quick test of basic functionality.
It's taken me close to 10 hours to get this written due to continuous maintenance calls tonight so I apologize if it's a bit scattered
