I'd track down the eeprom and check the supply voltages to it. If they are ok, try a little bit of hot air to warm it up and see if it boots then.
Failing that, you would need to check that there is communication being sent to it. And perhaps try and read its contents.
Disclaimer! I have never worked on this device, it is just the general path I would follow to diagnose/repair it.
