Hello all,
A friend of mine runs a machine shop near where I work. He's had trouble with a sensor on his Mazak CNC lathe so I started helping him out. One problem is that the sensor plugs in to a PCB but the connector has been reused several times (pigs tails, bits soldered on etc) and it's clearly reached the end of its life.
I contacted Mazak to ask what the connectors were but they didn't know/wouldn't say. My question is, can anyone identify the connector in the picture? I forgot to measure the connector pitch, I'll do that next time I'm at his shop. I hope it's an off-the-shelf part so I can buy some.
Cheers,
James
