Hey there,
I have some LED power supplies that I want to debug to learn a bit more, but I can't find the driver IC datasheet anywhere. The IC is a 6 pin SOT-23 like with "CB879" marking on top. I have been searching mouser for drivers similar, but most of the drivers I see are boost converters. This one is rated for 60-90Vac in 40-55VDC out.
I have some power supplies that hiccup after 63V and others that are working just fine. I probed the gate of the output MOSFET, on the ones that are working fine, the frequency is constantly changing but the duty cycle stays fairly the same across the 60V~90V input voltage, but on the ones that hiccup, the duty cycle is very close to 100% right at the 60V input voltage and then, when the output starts flashing, the gate goes from the normal behaviour to a much lower frequency with a very small duty cycle. Going back to the 62V at the input stops the flashing completely.
