Hello.
I got a supposedly functioning hp3478a multimeter off of ebay the other day and it appears to have some issues. First off, all of the functions are off by some amount. The dc volts range is usually off by around 2. In addition, the 2 wire resistance measurement is always overloaded, and it causes all of the other functions to have a extra high reading when deselected. I have not replaced any of the capacitors yet, but all of the power supply voltages are fine and the calibration data is still intact. I looked in the service manual and found that the U102 hybrid ic may be broken, which is completely unobtainable. Are there any other possible culprits for this issue or should I just buy another meter and pray that it has a working hybrid ic.
-Warsp
