Hello All,
Bought a Xantrex 500, 12Vdc do 220Vac Inverter on a local flea market but it doesn't work. Took out 4 Mosfet's of one side and with the diode test between drain and source after touching momentarily on the gate, all of them show 0,017V and the DMM beep's continuously, instead of the normal 0.7V diode forward voltage.
I presume these Mosfet's are bad but the ID markings are erased as pictures below show.
Does anyone have a clue of witch ones might be? or similar one's?
Thank you very much.
