Author Topic: Help identifying power rating of THT Carbon Resistors  (Read 619 times)
Offline danielbriggsTopic starter
« on: June 17, 2024, 07:17:02 pm »
Hi all,
I wondered if I could get a quick opinion of what power rating these old carbon resistors are? I'm repairing an old board, mid-90's era, and I've not used this sort of high power old carbon resistor before so difficult for me to gauge.
I know they're 22Ω, 5%; all connected in parallel.
They measure 17.5mm long, and 8mm in dia.
Would anyone hazard a guess at what possible power rating something in this size package of that era would likely be?
I'm tempted to put these 3W ones in, but just thought I'd check in with the collective-experts, if I'm way off. Can't harm to up-rate them, eh?  :-/O
https://uk.farnell.com/bourns/w3m22r0j/res-22r-5-3w-axial-wirewound/dp/2530207
Unfortunately I have no way to know the design spec of the rated current for this PCB.
Thanks in advance!
Dan
Offline McMax
Re: Help identifying power rating of THT Carbon Resistors
« Reply #1 on: June 17, 2024, 07:30:42 pm »
I think you're good to go with the 3 watts you linked, but you can fit the 5Watts of the same series.
At the end resistor are dissipating heat and it's just a matter of thermal mass, the bigger, the better  ;)
Offline fzabkar
« Reply #2 on: June 17, 2024, 08:39:21 pm »
Take care with wirewound resistors. Your application may not tolerate the standard inductive types.
https://4donline.ihs.com/images/VipMasterIC/IC/BOUR/BOUR-S-A0008961256/BOUR-S-A0008961256-1.pdf?hkey=6D3A4C79FDBF58556ACFDE234799DDF0
Non-inductive version is available upon request
Offline George Edmonds
« Reply #3 on: June 17, 2024, 11:08:13 pm »
Hi
A better question to ask is why have have four out of five burnt up and fifth has not?
 G Edmonds
The following users thanked this post: srb1954
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #4 on: June 18, 2024, 08:28:20 am »
Yeah, I'd be figuring out why they burnt first. Then when replacing them, space them a few millimeters off the PCB for good airflow for good measure.
« Reply #5 on: June 18, 2024, 09:18:44 am »
Thanks all for your replies; appreciated!
I'll get to the bottom of the overcurrent situation + swap out.  :-/O
Offline factory
« Reply #6 on: June 18, 2024, 07:46:31 pm »
The dimensions in this datasheet would suggest the old parts are 2W; https://www.hificollective.co.uk/sites/default/files/allen_bradley_data_sheet.pdf
We don't know what the application is, so can't advise the best replacement, something from the 1990s would have very few carbon comp resistors, they would be using them for the pulse rating, or non inductive properties.
Beware wirewounds can burn up badly in certain failures and make a right mess of your board.
« Reply #7 on: June 18, 2024, 07:49:17 pm »
Thanks all, that's really useful to know.
I'm not 100% as I don't have the part it was connected to, but it looks like they were part of a stepper motor driver.
The board was large and had lots of other things going on, but I think these resistors were responsible for that.
All the best,
Dan
« Reply #8 on: June 18, 2024, 08:59:21 pm »
Hi
The resistors are 1W Carbon Composition from the data given
G Edmonds
Offline factory
« Reply #9 on: June 19, 2024, 06:19:28 am »
They are 2W, look again, they are the third from the bottom of the table in the AB datasheet, dimensions A & E.
