Author Topic: Alcatel power supply identification  (Read 1398 times)
Offline more_starsTopic starter
« on: March 04, 2021, 05:37:02 pm »
Hello guys,
I have a pcb here given by one of my friends and hw did not know what it was but he knew I like electrical stuff.
I took a look at the PCB and it seems it is a power supply made by alcatel but I was not able to find any information about it.
On the label there is a 45V 5.3A DC sign but as I said, I do not know anything about it.
If there is any info on how I can get this thing wired and maybe use it with an rd6006 power supplie interface, that would be grate.
Thanks!
Offline madires
  • A qualified hobbyist ;)
Re: Alcatel power supply identification
« Reply #1 on: March 04, 2021, 05:54:43 pm »
48V DC is most likely the input voltage (typical for telco devices).
Online tunk
  • Country: no
« Reply #2 on: March 04, 2021, 06:06:19 pm »
Maybe you could check the voltage rating of the
capacitors, if some are 400-450V, then maybe?
« Reply #3 on: March 04, 2021, 06:31:35 pm »
Ohh, yep, I forgot about the input caps and so, there is no 400v caps and also there is no ac to dc rectifier.
Offline picburner
« Reply #4 on: March 05, 2021, 06:48:38 am »
In fact, the symbol Unicode (U+2393) indicates that the power supply must be DC.
Offline TheMG
« Reply #5 on: March 05, 2021, 02:31:40 pm »
I agree that 48V DC must be the input rating. Components and layout dont at all make sense for an AC power supply.
As for the output voltages, it looks like there might be several. Probably 12V, 5V, etc.
