Author Topic: Help identifying some ICs  (Read 1419 times)
Offline W1ngsTopic starter
    • The Luna Weyr
« on: May 10, 2023, 05:47:36 am »
I've got a few interesting ones here, one of which looks quite interesting. I've been able to find little about these, but I'm sure some will recognize them. Any ideas?
Slick as snot on cardboard.
Offline retiredfeline
Re: Help identifying some ICs
« Reply #1 on: May 10, 2023, 07:53:05 am »
That Motorola IC at the top right with the rounded corners and cute dimple on pin1 looks like the DTL chips I have and if 74 is the year, could be a fit. But the ID isn't familiar. Could be a custom or OEM ID. It could also be a non-logic IC too I guess.
    • The Luna Weyr
« Reply #2 on: May 10, 2023, 08:25:57 am »
Interesting! I do have a bunch of DTL (including MDTL) here but none of them look like this one. I've got other Motorola chips of that age for linear stuff.
Offline wasedadoc
« Reply #3 on: May 10, 2023, 10:36:05 am »
The one marked 710 might be a uA710 (mu A) comparator.
The following users thanked this post: W1ngs
Offline RES
« Reply #4 on: May 10, 2023, 12:13:15 pm »
(Motorola) M 7850 442-62 is a heathkit part number code. (442-62 not in this list: http://www.d8apro.com/heath3.htm )
« Reply #5 on: May 10, 2023, 12:35:52 pm »
Ha, MC1358P if this document is to be believed: https://www.yumpu.com/en/document/view/27722705/heathkit-cross-reference-italy
Offline Haenk
« Reply #6 on: May 10, 2023, 01:57:18 pm »
The 50210 look like Precision Monolithics (PMI).
Edit: The printing might confirm this: https://www.ebay.com/itm/333850317674
Edit2: PMI only did have a handful of chips in 1972, unfortunately, none of these resemble the part# of the ones shown. Maybe crack one open to confirm if it's an OPAMP or DAC.
Edit3: 29011 found here as well: https://physicsmuseum.uq.edu.au/cross-section-display-transistors-and-ics
« Last Edit: May 10, 2023, 03:01:16 pm by Haenk »
    • The Luna Weyr
« Reply #7 on: May 10, 2023, 05:53:32 pm »
I saw that site in my search for 29011; sadly no info though and I'm definitely not willing to open it.
Online factory
« Reply #8 on: May 10, 2023, 06:02:35 pm »
29011 is the custom counter IC used in the Advance DMM2 multimeter, I have one here that has two defective outputs.
« Last Edit: May 10, 2023, 06:04:39 pm by factory »
    • The Luna Weyr
« Reply #9 on: May 10, 2023, 06:04:10 pm »
Ah! That explains why I have these; I parted out three of those Advance DMM2 multimeters! Are you needing another chip for yours?
EDIT: I remember this chip now; it was pulled out (and mangled) and stuck to a piece of paper with a note saying it was bad and was expensive to replace. I'll keep an eye out if I saved any from the ones I tore apart.
« Last Edit: May 10, 2023, 06:05:47 pm by W1ngs »
    • The Luna Weyr
« Reply #10 on: May 10, 2023, 06:16:28 pm »
Found this other thread and a mention GI MicroElectronics (General Instrument). This explains the GIM marking. Apparently it might be an AY-5-4057. Just a BDC counter. I'll breadboard this up and see if it does anything. Here's the thread mentioning the chip https://www.eevblog.com/forum/repair/faulty-yet-irreplacable-ic/
Online factory
« Reply #11 on: May 10, 2023, 06:26:42 pm »
It's not the same as the as AY-5-4057, pinout is different, it more than just a counter, it does the latching & display multiplexing, I've got about 90% of the function with a board full of 74 series.
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg4615303/#msg4615303
P.S. since then I've found out my DMM2 does not match the circuit diagram in the manual.
« Last Edit: May 10, 2023, 06:29:28 pm by factory »
    • The Luna Weyr
« Reply #12 on: May 10, 2023, 06:29:33 pm »
Taking a second look at things, the PMI chips say CMP-01 on the bottom.... That is a well-known PMI comparator, but normally appears in an eight lead DIP or TO-5 style package... I dismissed the possibility of a DIP-14 package CMP-01 and shouldn't have. I found a 1976 databook from PMI depicting a DIP-14 version at http://www.bitsavers.org/components/pmi/_dataBooks/1976_PMI_Linear_and_Data_Conversion_IC_Products.pdf! (Page 7-1 [PDF page 106]).
I think I have some PMI DACs here... perhaps I shall waste some time and implement a vintage SAR ADC.
    • The Luna Weyr
« Reply #13 on: May 10, 2023, 06:31:44 pm »
The 4057 does latching and display MUX though? I see that the pinouts are different, so they must be different chips, but in the 4057 datasheet it does indeed provide multiplex outputs for four digits of display.
    • The Luna Weyr
« Reply #14 on: May 10, 2023, 06:36:02 pm »
I think you're right. Amusingly, the datasheet I found for the 50210 (CMP-01 on the bottom) mentions 710s!
Online factory
« Reply #15 on: May 10, 2023, 06:56:29 pm »
Yes they both have latch & mux, but the 29011 isn't quite a full 4 decade counter though, max count is 1999 for the DMM2 and once it exceeds that it uses the 2 from the 2000 count for the overload indicator lamp.
