Author Topic: Help identifying this part - 1178H  (Read 929 times)
Offline daisizhouTopic starter
  • Country: cn
« on: September 06, 2024, 05:03:09 pm »
Hallo everyone
I don't know what model this patch represents, I saw the mark is "1178H"。
If you know please tell me, thanks
daisizhou#sina.com #=@
Offline fzabkar
Re: Help identifying this part - 1178H
« Reply #1 on: September 06, 2024, 07:54:15 pm »
Can you provide some context? What are the surrounding components? Is the "8" likely to be a year code? Can you identify the Vcc and Ground pins?
  • Country: cn
« Reply #2 on: September 06, 2024, 09:34:32 pm »
The middle is connected to VCC and GND, and the other pins are connected to the inductor. Please see the figure below.
Looks like a DC/DC control chip.
Offline fzabkar
« Reply #3 on: September 06, 2024, 09:51:31 pm »
The IC appears to be driving 4 inductors, but there are no feedback pins. :-?
  • Country: cn
« Reply #4 on: September 06, 2024, 10:34:13 pm »
It looks like the 4 inductors connected to it are connected to the output jack
Each of these chips is always connected to 6 inductors, see the figure below.
Offline fzabkar
« Reply #5 on: September 06, 2024, 11:14:54 pm »
Could it be an ESD protection diode array?
  • Country: cn
« Reply #6 on: September 06, 2024, 11:18:08 pm »
It looks like a 74HC4052D driving 1178H.
ESD Protection Diode Array How do I confirm it?Should I disassemble a normal 1178H for measurement?
  • Country: cn
« Reply #7 on: September 06, 2024, 11:24:34 pm »
This is the actual connection after I measured it
  • Country: cn
« Reply #8 on: September 06, 2024, 11:46:55 pm »
Each 1178H is always connected like this.
VCC and GND are connected to a "3CWU" component, which looks like a voltage-stabilizing transistor.
Offline fzabkar
« Reply #9 on: September 07, 2024, 12:01:06 am »
  • Country: cn
« Reply #10 on: September 07, 2024, 12:16:21 am »
Offline fzabkar
« Reply #11 on: September 07, 2024, 12:22:49 am »
It appears to be a fixed 3-terminal 3.3V linear regulator. The pinout from left to right appears to be Ground, Vin, Vout.
« Last Edit: September 07, 2024, 12:28:26 am by fzabkar »
  • Country: cn
« Reply #12 on: September 07, 2024, 12:33:15 am »
Very true.I found that the output port and GND resistance is only 15 ohms.
I uninstalled the 1178H and the 15 ohm disappeared.
Finally 1178H is damaged,But I still don't know what the exact model of 1178H is
Offline fzabkar
« Reply #13 on: September 07, 2024, 12:49:53 am »
What is the device and what is the output port connected to?
  • Country: cn
« Reply #14 on: September 07, 2024, 01:50:06 am »
The sensor is connected.I don't know the details, because I didn't see the sensor appear, only the sensor interface
  • Country: cn
« Reply #15 on: September 07, 2024, 02:49:03 am »
I separated a normal 1178H from the PCB.
Use the diode range of a digital multimeter to measure each pin separately. The values ​​are shown in the figure below.
Offline fzabkar
« Reply #16 on: September 07, 2024, 03:10:41 am »
Similar to this?
https://www.ti.com/lit/ds/symlink/tpd4s009.pdf
BTW, could the device be an ECG? That could explain the "SKIN" on the PCB.
« Last Edit: September 07, 2024, 03:12:45 am by fzabkar »
  • Country: cn
« Reply #17 on: September 07, 2024, 03:17:43 am »
Similar to this?
https://www.flukebiomedical.com/products/biomedical-test-equipment/incubator-radiant-warmer-analyzers
This is the host introduction.The 5 interfaces below the display are connected to the 1178H
  • Country: cn
« Reply #18 on: September 07, 2024, 03:20:29 am »
Similar to this?
But there is another 3.3v DC voltage coming in,It turns out that the 1178H is short-circuited because the vcc3.3v port and GND are broken down.
I don't see any power supply in your schematic.
Offline fzabkar
« Reply #19 on: September 07, 2024, 03:22:06 am »
You have some interesting jobs.
  • Country: cn
« Reply #20 on: September 07, 2024, 04:31:27 am »
Thanks.I am more interested in simulators and analyzers in the biomedical field
  • Country: cn
« Reply #21 on: September 07, 2024, 04:34:30 am »
Can't find the same 1178H, can only choose the alternative shown in the figure below
