Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Help identifying this smd fuse
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help identifying this smd fuse (Read 244 times)
artvandalai
Contributor
Country:
on:
October 03, 2024, 02:53:57 pm »
Making this thread again, I need help identifying this smd fuse on a Philips sonicare pcb so I can order the correct part from digikey. I believe i blew the fuse attempting to fix another part of the board as it shows no continuity on the multimeter. I thought i bought the correct fuse but it was much bigger than the one I needed. I currently dont have a micrometer caliper to measure correctly. The fuse is next to a 1206 littlefuse 3.18mm x 1.52mm and a PTS815 SJG 250 SMTR LFS tactile switch 4.20mm x 3.20mm
https://ibb.co/V2vFdGqhttps://ibb.co/QFS4xrb
Last Edit: October 03, 2024, 06:33:23 pm by artvandalai
Logged
squadchannel
Frequent Contributor
Country:
deepl translate user
Re: Help identifying this smd fuse
Reply #1 on:
October 03, 2024, 03:01:19 pm »
littel "467003." ?
I am not sure if it is really a littelfuse. Various manufacturers make similar fuses.
Last Edit: October 03, 2024, 03:03:36 pm by squadchannel
Logged
artvandalai
thm_w
Super Contributor
Country:
Non-expert
Reply #2 on:
October 03, 2024, 10:51:59 pm »
You can just use your existing thread:
https://www.eevblog.com/forum/repair/help-identifying-this-smd-fuse/
Its going to be 0603 or 0805. You can compare to the FETs and measure those in Paint, or some other component that you can identify.
The 1206 will fit as well if you put some effort to mod it.
Logged
Profile -> Modify profile -> Look and Layout -> Don't show users' signatures
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
