Author Topic: Help identifying this smd fuse  (Read 282 times)
Offline artvandalaiTopic starter
« on: October 03, 2024, 02:53:57 pm »
Making this thread again, I need help identifying this smd fuse on a Philips sonicare pcb so I can order the correct part from digikey. I believe i blew the fuse attempting to fix another part of the board as it shows no continuity on the multimeter.  I thought i bought the correct fuse but it was much bigger than the one I needed. I currently dont have a micrometer caliper to measure correctly. The fuse is next to a 1206 littlefuse 3.18mm x 1.52mm and a PTS815 SJG 250 SMTR LFS tactile switch 4.20mm x 3.20mm https://ibb.co/V2vFdGqhttps://ibb.co/QFS4xrb
« Last Edit: October 03, 2024, 06:33:23 pm by artvandalai »
Offline squadchannel
  • Country: jp
  • deepl translate user
Re: Help identifying this smd fuse
« Reply #1 on: October 03, 2024, 03:01:19 pm »
littel "467003." ?
I am not sure if it is really a littelfuse. Various manufacturers make similar fuses.
« Last Edit: October 03, 2024, 03:03:36 pm by squadchannel »
The following users thanked this post: artvandalai
Offline thm_w
  • Non-expert
« Reply #2 on: October 03, 2024, 10:51:59 pm »
You can just use your existing thread: https://www.eevblog.com/forum/repair/help-identifying-this-smd-fuse/
Its going to be 0603 or 0805. You can compare to the FETs and measure those in Paint, or some other component that you can identify.
The 1206 will fit as well if you put some effort to mod it.
