Author Topic: Help Identifying this SSOP4  (Read 299 times)
Offline IngineerTopic starter
« on: May 13, 2024, 04:55:08 am »
I have 2 boards about a year apart with these SSOP4s which I believe are opto-isolators.  One is marked "1 [] 724" and the other is "1 [] 648" like this:  (So I believe the 3 digit must be the date code)
Can anyone come up with a datasheet?   I suspect the board is applying too much voltage across the output.
Offline fzabkar
Re: Help Identifying this SSOP4
« Reply #1 on: May 13, 2024, 05:07:31 am »
« Last Edit: May 13, 2024, 05:14:43 am by fzabkar »
« Reply #2 on: May 13, 2024, 05:13:23 am »
Thank you, Awesome!
