Author Topic: Help identifying this tactile switch  (Read 347 times)
Offline artvandalaiTopic starter
« on: July 26, 2024, 02:58:50 am »
I need help identifying this tactile button on a Philips sonicare pcb so I can order the correct part from digikey. https://ibb.co/52K09sf  https://ibb.co/FmhFyN2
Offline rich t
    • rtestardi's github pages site
Re: Help identifying this tactile switch
« Reply #1 on: July 26, 2024, 03:10:41 am »
I use these which look close:
https://www.mouser.com/datasheet/2/240/pts815-3050953.pdf
Note you can get different colors and different activation forces and heights -- not sure if that matters to you.
Or from digikey:
https://www.digikey.com/en/products/detail/c-k/PTS815-SJM-250-SMTR-LFS/9947846
« Last Edit: July 26, 2024, 03:24:05 am by rich t »
The following users thanked this post: artvandalai
Offline rich t
« Reply #2 on: July 26, 2024, 03:24:11 am »
And I think the "G" option is actually black with higher activation force (despite the picture):
https://www.digikey.com/en/products/detail/c-k/PTS815-SJG-250-SMTR-LFS/9947852
