Author Topic: Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?  (Read 269 times)
Offline artvandalaiTopic starter
This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
https://imgur.com/a/Yo217Fr
Bump
