Author Topic: Help indentifying a SMD T1 component  (Read 775 times)
Offline JudderTopic starter
« on: December 17, 2019, 03:14:34 pm »
Hi everyone
First post from me so I hope you are all well!
I'm trying to replace what I think is a transistor on a Japanese manufactured car engine boost controller (it's like a mini-computer) and wondered if anyone can help me with the identification of _what_ the original component is I need to replace.
On the PCB it is labelled 'T1' (top right corner of the photo) and has 5 inputs and 5 outputs so I'm guessing it's a transformer, but I can't seem to find any reference to the markings '386 Yf' so a little in the dark with what it is
From the shape it's 99.9% a coil on top of a PCB so inductor or transformer, and not a radial capacitor as there are more than two input / outputs
Any thoughts much appreciated!
Kindest regards
Alex
Offline TheMG
Re: Help indentifying a SMD T1 component
« Reply #1 on: December 17, 2019, 07:24:48 pm »
That's definitely a transformer. Probably a custom part, as a lot of such transformers tend to be, wound specifically for the required primary and secondary voltages required in that specific application.
Are you sure it's bad? Open or shorted windings?
« Reply #2 on: December 18, 2019, 12:38:31 pm »
Great - many thanks for the reply and yes good to know that I'm not a million miles away with my guess work!
It's definitely bad as when I went to see why the board wasn't working, the top coil part literally fell off the bottom silicon part - almost as if it got so hot over time and just cracked, thus separating the connector wires from the PCB part to the coil part
I have another board with the same part on - is there any easy way to check the outputs - I'm guessing I could meter them or check the various resistances to try and calculate what the outputs would / could be from those?
« Reply #3 on: December 18, 2019, 06:21:54 pm »
Here's a couple of extra images - I'm guessing from the 'Warning 75V' that one of the outputs of the transformer generates 75V and you can see on the PCB where it melted itself in - luckily PCB tracks seem fine
