Author Topic: help laptop motherboard thomson NEO14A-4sl64  (Read 116 times)
Offline mabarTopic starter
« on: December 14, 2024, 10:45:00 am »
Hello,
The motherboard has undergone a polarity inversion.
This short-circuited the 100µF tantalum.
After replacement, the A7SHB mosfet burned.
After replacement, everything works except the battery charge.
I made the partial diagram of the motherboard around the charging chip.
I took the voltages around the BQ735 chip, see photos.
I don't see anything abnormal on the voltages except ACDRV which is not boosted, I have 6.6v instead of ~18V normally?
I suspect a chip defect?
Here is my question:
but I also have a connection between Q1 and Q2 which goes to mosfets can they intervene in blocking the charge?
thank you
« Last Edit: December 15, 2024, 07:44:01 am by mabar »
