Hi All,
I have been looking around in Canada for some 93L34PC IC's but so far I am unable to find any. I have no idea how I could check this Logic IC . Could someone clue me in on testing this device. I have never tested a logic IC. lots of background in Electronics but this is a black hole. I have the data sheet and Ill post the 1st page here.
Sorry for the lame request.
Thanks in advance.
Looks like your in luck, the 54LS259 & 74LS259 are the TI equivalent to the 9334 93L34 and seem to be easier to obtain.
Thanks so so much Dave !!
David ,
Just curious , how or maybe I should say where did you find the cross reference to that latch?
Again Thanks
Garry
My IC Substitution Manual (1990) lists the following as substitutes for the 9334:
National DM9334
Signetics N9334, S9334
The problem is; HP 4261A LCR Meter.
Someone removed a board full of logic chips and with a Hot Air gun and took all the chips out. He heated the board so much that in some places it is burned a bit. With a TL866 II programmer I found almost 90% of the logic Ic's no good. I figure it is from over temp. The guy who did this installed IC sockets all over the PCB , so at least one good thing. I am still waiting for 3 IC's ( 93L34PC) and then I will be able to see if there is any other problems..
well, back to the drawing board.
Have a good one !
