Hello
I've been repairing a HP 5316B Universal Counter and have everything working well except the gate time.
Come to find out when I took it back apart and removed it completely from the case the Gate Pot was sheared off the PCB.
The Part is A1R31, 2100-3905 500K 300deg, Pot with Switch
You can see in the pictures below the part itself and how it sheared off
I've looked on the web for this part (long shot I know)
So I have a few questions
1. i see it's riveted together. can I remove the rivets and try to repair the lugs so it can be resoldered?
without a rivet gun that small can i use small screws to put it back together?
2. is it worth contacting the HP (just using the original name) to see if they may have any of them?
3. anyone know where I might obtain one? I tried ebay and no luck and found one compant on the web but they are not replying
4. anyone have one they'd be willing to sell?
Here's the pics showing part number and the sheared off pcb pins
