Author Topic: Help locating relays  (Read 900 times)
Offline jheatacTopic starter
« on: November 12, 2017, 03:38:51 pm »
Hello,
I cannot find a source for some Class F Insulated relays for an oven board:
Omron G5LE-1-CF 9VDC (or SongChuan 812H-1C-S 9VDC)
SongChuan 835NL-1A-F-C 9VDC
SongChuan 855AWP-1A-F-S-B 12VDC
I can located them, but cannot find a supplier with stock or a minimum less than 100 units.
Anyone out there have a source?
Thanks!
Offline Samogon
Re: Help locating relays
« Reply #2 on: November 12, 2017, 07:28:54 pm »
Thanks for the reply. It seems that the 12V options are more popular as I have found stock.
The smaller 2 are 9V, and the larger is 12V.
I don't have the oven around to see what voltage it is actually operating at, so I was trying to match what was in there.
