Author Topic: Help me! My power supply Gwintek gpd-3303S does not increase when turn knob up  (Read 4013 times)
Offline uoemxTopic starter
  • Country: vn
   I recently bought a old GPD-3303S power supply. When i turn on and turn knob up it not increased but only at 4.5V.
Link here:
https://youtu.be/CturhOBos7U.
Everyone help me please!
Offline bitseeker
Welcome to the forum, uoemx!
That's an interesting problem. Does it do the same thing with nothing connected to the outputs? What about when there's nothing connected and both outputs are turned on?
If you recall 30V from the memory, then turn the outputs on, do you actually get 30V on both outputs?
  • Country: vn
Thanks bitseeker
all are normal except the problem above
Here:
https://youtu.be/cFaa71qfRLE
Offline innkeeper
What happens when you try setting the voltage via the usb port?
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline plurn
To put this in a simple way to start with, I would suspect that there are faulty components, or damaged soldering, or loose cables, or blown fuses (there are many fuses), inside the unit that need to be repaired.
Since you have not opened it up to check to see if there is any obvious damage, I kind of expect that you are not familiar with repairing damaged electronics. Perhaps you should tell us about your level of experience with electronics so we can see if we should try and help you troubleshoot, or just advise that you should get an electronics repair technician to fix it. It can be dangerous for beginners to mess with high voltages inside electronics if they do not know how to be safe.
Anyway, to start with something you can try without opening it up. Make sure you have set the input voltage correctly on the back of the unit to match the mains voltage in your area.
Found this service manual linked in another thread. May be of help to you or others here trying to help you: http://www.eltest.hu/pdf/GPD3303SM.pdf
The following users thanked this post: ebastler
Offline innkeeper
looking over the manual seems you can get updated firmware from gwinstek, maybe the firmware got corrupted.
seems like an easy thing to try.
Offline plurn
user manual:
https://www.gwinstek.com/en-global/products/downloadSeriesDownNew/7837/1474
There is a remote control section starting on page 43.
There is an interesting command:
ERR?
"Returns the instrument error messages."
Don't know if it would tell you what is wrong but maybe it will? They might just be command errors rather than real errors.
Links to software/drivers if needed https://www.gwinstek.com/en-global/products/detail/GPD-Series
  • Country: vn
Thanks everyone. I tried installing on the computer with the command line but below 4.5v it was ok on 4.5v, nothing happened. I can't find the firmware link to load it
Offline innkeeper
in the manual it says you have to contact them to get it. they don't post it on their site.
for what it is worth, I had to request the firmware form them via email for my GWInstek meter and they sent it to me, no problems.
it did take them a few days to reply though
« Last Edit: May 13, 2019, 05:39:47 am by innkeeper »
  • Country: vn
Thanks innkeeper. I will contact gwintek, but now you have the firmware of this power supply? Can you send it to me?
Thank you very much
Offline innkeeper
no, I don't have it for the power supply.
i had contacted them once for firmware for a meter.
Offline TopLoser
Is it possible you have set an upper voltage adjustment limit on that channel?
I think it's possible to do that on these units, to stop you accidentally exceeding a set point by spinning the knob too fast.
Offline bitseeker
Thanks bitseeker
Thanks for the video. It does look like the analog parts of the power supply are functioning properly. Since the output does go above 4.5V, all the transformer taps and relays seem OK. The short circuit behavior looks fine, too, so it's regulating the output as expected.
The manual doesn't indicate that there is an over voltage protection (OVP) setting, but it acts like there's one set to 4.5V. So, it may be a software/firmware problem.
Nevertheless, take a look inside for any loose wires or bad solder joints.
That's what I was going to ask next. Can you try setting different voltages via USB? Does that work as expected and provide proper output?
Offline rfdes
I've attached the firmware that GW sent me some time back.  I have no idea if it is the latest.  I also have a service manual if you need that.
Good luck -
Jim
Offline innkeeper
that was my first thought too.. but after scouring the manuals, i didn't find such a documented feature.
  • Country: vn
I controlled it via computer
https://youtu.be/Blr1HWVNJI4
  • Country: vn
And then I upgraded the firmware of rfdes
https://youtu.be/SxdNumUvGKI
Thank you everyone for your enthusiastic support.  Thanks rfdes
Offline bitseeker
Yay! :clap:
That was the first time I've seen one act this way. Glad it was an easy fix.
« Last Edit: May 14, 2019, 01:56:22 am by bitseeker »
  • Country: vn
 :-// |O |O
There is a new problem on channel 1 after firmware update.  Previously this channel used normally as the video above.  I calibrated but failed
https://youtu.be/5HeAoviWumg
  • Country: vn
Channel 1 runs wildly  |O |O |O  :-//  :-//  :-//
https://youtu.be/dDZmxmR7m60
Offline bitseeker
Did this happen only after calibrating?
Try reflashing the firmware. Maybe the microcontroller (or external) flash/EEPROM is bad.
« Last Edit: May 14, 2019, 03:25:05 am by bitseeker »
  • Country: vn
Hello bitseeker. I have reflashed the firmware twice.  I also calibrated before and after the same results on channel 1
« Last Edit: May 14, 2019, 06:28:00 am by uoemx »
Offline bitseeker
The only other things that come to mind at the moment are to (1) see if USB programming is also behaving badly and (2) check if you can get a copy of some older firmware or ask GW Instek if there is any compatibility issue between your serial number and that firmware version.
Otherwise, any other debugging will probably be inside the power supply, although so far all the problems seem to be software.
  • Country: vn
Thanks bitseeker for supporting.  I contacted and sent identification to Gwintek.  When will you come to Ho Chi Minh Vietnam, I will invite you to coffee!
Offline bitseeker
Thanks, uoemx. Hopefully, they have an answer. I haven't seen one behave like this before.
  • Country: vn
Thanks for everyone's help.  After I contacted gwintek, I received the support that is a version 2.11 firmware for Gwintek gpd-3303s power supply.  After firmware upgrade, channel 1 is still wrong, after calibration and this is the result
https://youtu.be/lPnQrTPfFgo
Thank you once again for your support.  Wish everyone health and success
Offline bitseeker
Looks good. :-+
Offline innkeeper
Congradulations  :-+
 :phew:
Offline evgen2910
  • Country: ua
Hi, are you Gwintek working properly? Can you send me a firmware what GW sent to you? I have same problem  |O
  • Country: vn
Check inbox
Offline Zlodey
  • Country: cz
Please, send me firmware v2.11 for Gw Instek gpd-3303s. Thanks!
  • Country: vn
Here you are: Power supply Gw Instek gpd-3303S firmware
http://www.mediafire.com/file/oc6itjq83u4s992/V2.11.7z/file
« Last Edit: April 15, 2020, 06:42:55 am by uoemx »
The following users thanked this post: ratmole
