Author Topic: SAMSUNG washing machine doesn't power up  (Read 1260 times)
Offline DennisLoiTopic starter
« on: July 08, 2023, 09:56:25 am »
I have a washing machine that has stopped in the middle of a cycle and showed an 'UC' error. On the SAMSUNG's site it says that is 'is related to the excessive fluctuation of the power supply voltage'. I turned it off and now it doesn't turn on anymore.
Analysing the main board, I've checked low voltage power supply and it seems to work, it outputs 37V (or something like that, I don't remember the exact value). On some connectors I've measured 5V and 12V.
In the same board there is also a relay connected to the input that, when active, powers other components (like the door lock) and the main rectifier circuit that powers the inverter.
If I bypass that, the machine turns on and after a couple of seconds I can hear the relay activating. At this point I can remove the bypass and the machine stays on. (I haven't tried to run a cycle)
At this point I'm not sure on what is the problem. The description of the error code makes me think that it has something that measures some kind of voltage? (I don't know what it checks and where), so maybe that is faulty? Or I'm missing something else?
I've attached a simplified schematic  that I've drawn while trying to understand how it works. 1822333-0
Moreover, I've found a service manual online that have some details on the wirings: https://www.manualslib.com/manual/2797277/Samsung-Ww6000j-Series.html
Offline ramussons
  • Country: in
Re: SAMSUNG washing machine doesn't power up
« Reply #1 on: July 08, 2023, 12:25:48 pm »
2 Points.
That GND cannot be ground. That will simply short that power supply bridge.
Track the source of power for the Relay. How does that operate in the first place?
Offline marhuum
  • Country: kh
« Reply #2 on: July 08, 2023, 01:31:09 pm »
If I bypass that, the machine turns on and after a couple of seconds I can hear the relay activating. At this point I can remove the bypass and the machine stays on. (I haven't tried to run a cycle)[/url]
I don't get, why don't try to run operating it then
Some of such machine Uc is to mean low Voltage too, sometime just reset/clear memory would work, ie. let it powerless for a minute or so
« Reply #3 on: July 08, 2023, 02:05:20 pm »
I haven' tried to run because the machine was in pieces and not properly assembled ;D .
But the main reason was that I didn't like the "hack" and even if the machine had worked I wouldn't have resolved anything because as soon as you turn off the machine, you can't turn it back on.
I guess one possibility is to bypass permanently the relay but I don't like that because I don't fully understand why it's there.
I hope this clarifies. Thank you
Offline marhuum
  • Country: kh
« Reply #4 on: July 08, 2023, 02:11:50 pm »
suspect that when the Uc happened it'd work back just by unplugging it waiting it  for a minute or so
« Reply #5 on: July 08, 2023, 03:04:59 pm »
Ah sorry I didn't clarify it. The machine stayed off and unplugged for a couple of days. Still doesn't work.
« Reply #6 on: July 08, 2023, 03:43:15 pm »
The relay is powered from a 12V rail generated by a kia78r15pi. However the enable pin of that regulator is not active (I'm not sure who controls it as it's under an heatsink which is a pain to remove).
I've forced the regulator on with a resistor and the it works. I have also confirmed that the transistor that switches the relay works.
« Last Edit: July 08, 2023, 04:06:37 pm by DennisLoi »
