Author Topic: Help me identify this mosfet.  (Read 1095 times)
Offline jurgis1991Topic starter
  • Country: lv
« on: June 20, 2020, 02:47:12 pm »
[img src="https://ibb.co/y8nSZBV"][/img]
Dose anyone know where to get datasheet for this mosfet ?
It is used in makita cordless fan.For controlling speed(PWM).
Offline Doctorandus_P
Re: Help me identify this mosfet.
« Reply #1 on: June 20, 2020, 05:50:05 pm »
Do this in a few steps:
1). Search for a few sites with SMD marking codes.
2). Type the code on your FET into a few of those sites.
3). Compare results.
Offline fzabkar
« Reply #2 on: June 20, 2020, 10:02:46 pm »
AOI4144, Alpha & Omega, n-ch MOSFET, 30V, 55A, 8mOhm Rdson:
https://media.digikey.com/pdf/Data%20Sheets/Alpha%20&%20Omega/AO(D,I,U)4144.pdf
The following users thanked this post: jurgis1991
  • Country: lv
« Reply #3 on: June 21, 2020, 03:28:58 pm »
Thanks for the help.How did you found out what device it was ?
Offline PA0PBZ
« Reply #4 on: June 21, 2020, 07:11:41 pm »
If you google for "I4144 mosfet" it's on top of the hits.
Offline Audiorepair
« Reply #5 on: June 21, 2020, 07:48:35 pm »
I googled for 14144 Mosfet when this post first appeared, and found nothing.
Now I realise the part is actually I  4144   where I is the letter "I", not the number 1.
Offline PA0PBZ
« Reply #6 on: June 21, 2020, 08:00:46 pm »
Yes, that's the difference between not finding anything and having it done in 10 seconds, been there, done that  :palm:
Offline Audiorepair
« Reply #7 on: June 21, 2020, 08:11:22 pm »
One might think that manufacturers would try and avoid using letters such as I and O in their nomenclature, especially since devices are nowadays so much smaller and difficult to identify, particularly when they are burnt or blown up.
Offline fzabkar
« Reply #8 on: June 22, 2020, 03:16:30 am »
I recognised the logo, so that helped a lot.
