Author Topic: Help Me Identify This Part  (Read 905 times)
Offline falcom
« on: April 04, 2018, 02:01:01 am »
I am trying to replace the part labeled T1 in the picture below. It looks like an inductor but it is not.
Any help is appreciated.
Dave
Offline Samogon
Re: Help Me Identify This Part
« Reply #1 on: April 04, 2018, 02:40:20 am »
Pulse transformer
Offline Alex Eisenhut
  • If you can buy it for 4$ on eBay, why design it?
« Reply #2 on: April 04, 2018, 03:04:41 am »
It's an array.
https://www.digikey.ca/product-detail/en/bourns-inc/SRF1280-220M/SRF1280-220MCT-ND/2458614
A pulse transformer would be used for signals, not surrounded by beefy power parts and traces like this.
You can see a LT1763 LDO after it.
Offline falcom
« Reply #3 on: April 04, 2018, 09:29:11 pm »
Ok so its a dual winding inductor. Icant find the exact match. It is from about 2004.
It appears to be a 10uf. The way I understand it the dual winding inductors are labeled for parallel  so 100 would be 10uf in parallel.
The measurements are (aprox) 6.8 mm x6.8mm x 2.3mm thick
I hate to be a pain but my google searches have come up empty so far.
A manufacturer would be helpful.
PS Thanks Alex for putting me on the right track.
« Last Edit: April 04, 2018, 09:42:53 pm by falcom »
Offline coromonadalix
« Reply #4 on: April 04, 2018, 09:57:09 pm »
have you tested the coils for conductivity,  why are you sure its defective ?
You have an 5 pins sot23  near it, it may work like an buck boost converter or an miniature pwn psu  before the lt1763 ...
100a  must be the coil value  100 uh ??
Offline falcom
« Reply #5 on: April 04, 2018, 11:07:18 pm »
The 5 pin that feeds it is a LT1930 buck boost convertor.
Voltage input is 6 volts.
The unknown part shows a dead short across all pins.
Offline Samogon
« Reply #6 on: April 05, 2018, 02:03:00 am »
It is probably not dead short, it just has really low resistance, like few mOhms. You have to measure it with LCR meter, to be sure it is still in 100uh range.
Offline falcom
« Reply #7 on: April 05, 2018, 03:07:09 am »
Since it has dual windings they should be electrically separated..
Offline Samogon
« Reply #8 on: April 05, 2018, 04:25:04 am »
Did you desolder it? Anything can happen
« Reply #9 on: April 05, 2018, 07:36:26 am »
in ohms you may read a short but with frequency its an other story, we have small transformers at my job,  short or almost 0 ohms  but they run at 27 mhz, thats a difference .... if the pwm ic is dead,  sure you'll think its short  ??
It may be an inductor with 4 pads too ??  test it with an lcr meter
Offline falcom
« Reply #10 on: April 05, 2018, 03:37:06 pm »
I think I found it.
 It is a coupled inductor which is 2 separate windings in the same package so no DC between the two.
It is a SUMIDA CLS62-100 which Digikey and Mouser show as a standard inductor (not coupled)
I found it from the LT1930 datasheet which had the exact circuit layout in their circuit examples with parts listings.
Thanks again for all your help.
