Author Topic: Help me identify this relay  (Read 695 times)
Offline CrazyTigerTopic starter
  • Country: my
« on: February 21, 2021, 11:26:28 pm »
Hi All,
I am trying to refurbish an old Thomson TRC-350 HF Transceiver. The ATU part is not behaving properly and I found most of the relays are very sticky. Would someone please help me identify the relays.
Offline james_s
Re: Help me identify this relay
« Reply #1 on: February 21, 2021, 11:31:40 pm »
I'm not a relay expert but they look fairly standard. Have you tried cleaning the existing relays? It looks like you might be able to pop the dust cover off and clean up any accumulated goo causing it to stick, or you might try degaussing them.
Offline thermistor-guy
« Reply #2 on: February 21, 2021, 11:45:22 pm »
"EE" = Eichhoff Electronics?
Eichhoff p/n E3201 shows up in a Finder cross reference here:
http://www.automation4less.com/pdfs/findercrossref.pdf
Online bdunham7
« Reply #3 on: February 21, 2021, 11:46:56 pm »
If you have access to the Omron G2R series, I think they look the same.  You'd have to match up the exact voltages, contacts and so forth.
