I got a Anritsu 331D which is failing self-test (intergrator fail). I see no RF level or sweep happening. Taking things apart i found the input section is defective, likely fried from high rf power injection.
The amplifer, what I believe is NBB400 is dead, this can be easily replaced, but I am stuck with two component that have turned open, and sadly no marking on them. My only option is now is to compare it with another board which i dont have or by some miracle someone have the circuit diagram. Can someone help me out here.
My Guess (i might be wrong:)
Blue chip, is a 50 ohm resistor.
The SOT23 marking (RS2) maybe a detector diode, it makes sense, since the output of amplifier is fed into test port, and there is not other circuitary to monitor the output power
But the black chip, i have no idea what it could be
