Hi there everyone. Thought I might throw this one out to the hive mind.
Scenario :
I have three sets of 30 channel DMX controllers :
https://www.aliexpress.com/item/32993494983.html?spm=a2g0s.9042311.0.0.27424c4dpow2erI had them all wired up to a DMX shield on an Arduino.
I wasn't happy with the quality of the DMX signal so I hooked up my scope to pin 3 (maybe 2) of the DMX line. I then managed to briefly short the ground clip of the scope probe to the +12v supply line while heading for the ground terminal (well done Bumblefork!).
Unsurprisingly they don't work any more (*).
When I say don't work I mean they don't respond to DMX data. They *do* work if I use the DIP switches to put them in demo mode.
So I have the DMX units connected to a known good DMX device (an Enttec DMX USB Pro2) and have begun probing away.
The DMX data on pins 2 + 3 go in to a SN75176B differential bus transceiver (8 pin SOIC on low LHS near DIP switch). I've had a look at the output (pin 1) [see image] and it doesn't look out of place.
The signal feeds pin 4 of the "mystery" 28 pin IC. There's a crystal (24.000 MHz) on pins 6,7 and the output is on pin 13 (when in demo mode). There's no markings on the IC. There is a logo / marking in the listing photo but not clear enough to make out.
I'm at a loss as to what has failed here - the transceiver looks OK, but I can't see how the over voltage would have made it by the transceiver and damaged what I presume is a MCU. Could always swap out the transceiver. Happy to do some DaveCAD drawings if required...
Any thoughts on how to proceed or what to look at? I know it's only $150 of gear but I'd like to redeem myself
