Author Topic: Sunkko 737G spot welder  (Read 679 times)
Offline hpmaximTopic starter
« on: June 23, 2023, 05:30:07 am »
I have a Sunkko 737G which has always worked fine for me.  A few days ago, I turned it on, and it worked fine.  I turned it off, and then turned it back on about 15 minutes later -- and the fuse in the back blew immediately as I flipped the on-switch.  It appears to use a glass 30A fast-blow 5*20mm fuse.  I didn't have any but a coworker gave me a 20A fast-blow ceramic fuse.  I tried the 20A fuse, and it seemed to last 2-3 seconds before blowing (I think it took a lot longer to blow than the original 30A fuse).  It seems there is a legitimately large in-rush current.
I see a couple scenarios here:
1) There's some legitimate problem with the welder.  I opened it but didn't see any obvious scorch tell tale scorch marks (there was someone else on here, RustyCaliper) who had a component blow up right before his fuse blew.  But I don't see clear evidence of that.
2) The original fuse blew because the large inrush currents eventually wore the fuse out to the point that it blew.  The 20A fuse I replaced it with just wasn't enough because, it legitimately needed a 30A fuse.  This seems like a poor design to me (that's very little margin on the fuse, and the inrush current is wearing out the fuse?) and I'm wondering if I want a slow-blow fuse, perhaps with a smaller amperage.  Ultimately, the line is on a 15 or 20 amp breaker which obviously takes longer to trip than a fast blow fuse -- making me wonder what the point of a 30A fuse is that protects against extremely high inrush currents, but also false blows after a while.
Re: Sunkko 737G spot welder
« Reply #1 on: June 27, 2023, 03:26:13 am »
Replaced the fuse with a 30A ceramic and this time the circuit breaker tripped, so there's something wrong with the machine, the problem isn't the fuse.  I didn't see any clear damage to any component, although D3 looked like it might be a bit buggered.  Does anyone know these machines enough to aid me in diagnosing the problem?
Offline ferrisd65
« Reply #2 on: July 09, 2023, 11:01:35 am »
Offline marhuum
  • Country: kh
« Reply #3 on: July 10, 2023, 12:19:21 pm »
put its schematic
do google: 'list of electronic. component which will get short when it's faulty'
likely here; hi-power Mosfet(s)
that's in primary T, because this kind device should principally just hi ampere SMPS
