I've got a pair of audio amplifier boards, those have been used in a hungarian made active studio monitor (Beag HEC45). Back in the 80's this was a state of the art stuff, at least in the eastern block...
Nevertheless the amplifier cuircuit is also very interesting, and is potentially can be a "good sounding" amplifier, it is a rather complicated circuit but well thought out IMHO. See the schematic diagram attached.
I got the boards defectly, but they are original boards, not a replica or remake (to make sure for you that the PCB layout is as it should be). There were a handful burnt resistors and shorted/open diodes and transistors in each module, all in the power output stage. All components were replaced in pair, replaced transistors got matched for hfe, etc.
After replacing the deffective components now I am strugling with heavy oscillation in both modules. The oscillation frequency is at about 100-500kHz (see later) and a few Volts peak to peak.
I have tried quite few things, but with little success so far:
-As I've mentioned these board are original, I assume these were working properly at some point. All components in the input stage and VAS looks original and identical on both boards.
-The power supply that I'm using is linear, the input stage runs from +/-47V for this I've built a stabilized supply, the power output runs of two 22000uF smoothing caps and two 27R series resistor for current limiting in a possible hiccup.
-The board currently runs on my bench, no case etc.
-The board as is oscillates at ~200kHz. Since the output stage is a compound-darlington I've removed the output transistors (2N3055 and BDX18), then the oscillation frequency increased to 500kHz.
-I've tried to further simplify the output stage by separating T15 and T16 from the rest of the output, and by dividing R44 into two halves, I reconfigured the global feedback network to the middle point of R44. In this case the oscillation frequency got down to ~100kHz, but still there.
-I've tried to play with different grounding schemes -> no difference at all.
-Replaced all electrolytic capacitors related to power supply bypassing, even increased values, added more capacitors etc. ->nothing
-If I short together the inverting and non-inverting inputs of the amplifier, the oscillation stops (at least then...)
-Removed C5 ->nothing
-Even dared to modify C22 to 100nF instead of 10nF, then in steady state the oscillation was absent, but as soon as I put some input signal the oscillation (this time a very distorted one) kicked in and remained afterwards.
-Now I only focus on one board with my experiments, but initially I confirmed that both boards oscillates roughly about the same way, when fully assembled.
I am starting to run out of ideas how to diagonse further...
