I tried searching for this issue alot but couldnt find the solution yet.
Hi, I recently acquired a pm3295 crt based scope. It came in as "not working". Although I already knew this was a common rifa job. Fast forward a bit and I have this problem sorted. Scope came on, everything worked. No weird smell nothing. Well this scope has one nasty problem with it and that is that you have to remount the outside cover, which is super hard. I followed the instructions in the manual 100% and overdid the instructions (read extra securely). (Add cover and lay the scope crt facing down) Now comes the fun fact that after reseating the cover, the crt wont come on again (everything else is working , auto set, triggering). No whining noises anymore, no trace or anything on the crt. Im thinking that the HT is somehow off since I cant hear a whining noise.
Thats where I need some advise. I already checked the focus and that part seems to be functioning as it should. The fillaments are also on. I dont think I killed the crt by following the instructions, but yeah, where should I go now? I have the full, printed service manual with it.
