I'm currently poking away at a HP 437B Power Meter here and running through some tests.
One of the tests was to check the noise on the various voltage rails and if it was more than 10mV, the manual states that filtering caps probably need to be changed.
It was a little over 10mV, so I pulled the old capacitors out and replaced them with new, but I am now getting MORE noise, like 30mA+ etc.
I have measured the capacitors and the only obvious thing I can see is the old capacitors on the output of the vregs have a much higher ESR.
Attached is the power supply schematic, it all looks like a pretty basic design, the HP schematic is basically a copy of the data sheet reference designs it seems.
I have replaced C3, C4, C5, C6, C7, and C11. C12 is a
Kemet T110 Hermetically sealed Tantalum which I didn't replace.U1 is a LM2935.U2 is a LM325H and isn't anything special either. There is no mention about ESR that I can see in the data sheets.
The ripple on the unregulated side after the capacitor swap are as follows (I didn't measure before):
+5V: 496mV Peak to Peak
+15V: 776mV Peak to Peak
-15V: 648mV Peak to Peak
Here are the measurements I took with my Der-ee DE-5000 LCR meter, it doesn't have great resolution for low ESR, but I can fire up my HP 4276A if more accurate measurements are needed.
C3/C4
Old - 470uF, 50V Sprague 674D
Measured 652uF/481uF, 0.0ohm ESR
New - 470uF, 100V United Chemicon KMG
Measured 419uF/420uF, 0.1ohm ESR
C7
Old - 4700uF, 25V Sprague 674D
Measured 4610uF, 0.0ohm ESR
New - 4700uF, 35V United Chemicon KMG
Measured 4620uF, 0.0ohm ESR
C5/C6/C11
Old - 10uF/10uF/10uF, 25V United Chemicon KM Axial (Equivalent to KMG)
Measured 8.5uF/8.4uF/8.4uF, 18.3ohm/16.2ohm/19.4ohm ESR
New - 10uF/10uF/10uF, 50V Nichicon VX
Measured 9.8uF/9.8uf/10uF, 5.7ohm/5.5ohm/5.2ohm ESR
C12 Tantalum
100uF 10V Kemet T110
Measured 100.7uF, 0.2ohm ESR
Any ideas what to try to get this noise on the output back down under 10mV???
Should I up the capacitance on C3, C4 and C7 or try low ESR caps? Or maybe the new caps on the output side are too low ESR?
