Author Topic: HP 3458A 8051 on ADC Board - Atmel v. Intel versions  (Read 541 times)
Offline martinr33
« on: December 14, 2017, 09:15:26 pm »
I read the code from both an Intel chip, and an Atmel chip.
The code is identical. Therefore, there is no benefit to upgrading to the Atmel version. Like I did... although the exercise did prove the point for me.
Thought I would post this to save others the effort.
Offline SaabFAN
Re: HP 3458A 8051 on ADC Board - Atmel v. Intel versions
« Reply #1 on: December 14, 2017, 09:23:31 pm »
Well, it's an 8051-Core. So they more or less have to be identical :)
But good to know that both chips work. Allows to choose the cheaper chip/the one still in production - If I remember correctly, Intel stopped making 8051-Micros.
Offline Scopetechniques
« Reply #2 on: November 22, 2019, 08:41:37 pm »
I had an older A3 module that had 80C51 Rev 1 code on it and was able to install Rev 2 code and it works.
I don't know what the changes were to go from Rev 1 to Rev 2.
FYI the REV 1, REV 2 is what is reported when you execute REV? and the 3458A returns 9,1 or 9,2 (assuming you have latest main processor firmware Rev 9).
--Victor
