Author Topic: Help needed DATRON 1059  (Read 237 times)
Offline Al the Pal
« on: November 17, 2019, 08:41:29 am »
Hello everyone,
is there anyone out there who has got a service and operation manual for an old DMM Datron 1059 ?
I've been looking for such a manual all over internet and EEVBlog ofcourse.
I bought the DMM on E**Y for cheap and all the leads on the test posts on he inside are not connected.
873772-0
Also sometimes on powerup the display fails.
I would like to "allways measure voltages" but the PCB has hardly any markings on it.
I just love these old instruments and would like to bring it back to life.
Alex
- Attachments and other options
Offline Gyro
Re: Help needed DATRON 1059
« Reply #1 on: November 17, 2019, 10:45:40 am »
I'm pretty sure the closest you're going to find is the 1055 service manual, I uploaded one to KO4BB a few years back... http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=06_Misc_Test_Equipment/Datron
The main difference with the 1059 is that it has a current converter board. The rest of it should be pretty much identical - although I think the 1059 has range LEDs, I'm not sure how those are implemented.
The cable from the Analogue board -often labelled DC isolator (Red Blue White) should be connected to the Volts/Ohms input terminals - Red:Hi, Blue: low, White:Guard.
I can't remember what current terminals the 1059 has. The brown and blue are clearly the current shunt connections, if the current terminals are brown and blue then they should match up one-to-one. The black wire appears to be also connected to current low (blue). This might also go to input Lo but I can't be sure of this.
For now, I would just connect the voltage wires and leave the current converter wires safely disconnected (the current converter board is an option anyway). I can't see any sign of an ohms converter option board or an RMS (AC) converter.
You will hopefully find that the main Analogue board and A/D - Display board are more or less identical to the ones on the 1051 - Datron made a lot of use of common main boards and option boards across the 104x and 105x range.
Hopefully that will get you started (you're probably going to need some nuts for the terminals) and give you voltage readings.
If you want to post more photos then it should be possible to see exactly what capabilities it has (apart from 5-1/2 digit resolution DC volts and current). It would be interesting anyway, I've never seen the internals of a 1059 in the flesh.
EDIT: Just looking at photos from an old ebay listing, yes, Brown and Blue should go to the same coloured Current Hi and Lo terminals. I'm still not sure about the black, if it is indeed connected to the blue wire, then it probably goes to Volts/Ohms Lo. If separate then hold off.
« Last Edit: November 17, 2019, 10:54:28 am by Gyro »
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline Al the Pal
« Reply #2 on: November 22, 2019, 05:52:39 pm »
Thx a lot Gyro.
I'll take a look into these serice manuals and try to take a few hi-res pics from the pcbs.
Just a little problem.  The manual 1055 isn't there anymore :p
You wouldn't happend to have a fresh copy?
Alex
« Last Edit: November 22, 2019, 05:54:19 pm by Al the Pal »
Offline Gyro
« Reply #3 on: November 22, 2019, 06:37:27 pm »
Doh, sorry. I meant the 1051. :palm:   (The 1055 is a DC-only voltmeter in a smaller case).
Chris
