Author Topic: Help needed to identify thermistor value in failed Avaya PSU  (Read 1066 times)
Offline alanbTopic starter
« on: December 18, 2018, 10:50:12 am »
I'm repairing the failed PSU in an Avaya IP office 500. The inrush limiting thermistor appears to have failed, the markings are S.10 K275. Can any one tell me what the resistance value when cold should be or alternatively the equivalent part number on Farnell or RS websites?
Thanks in advance
Alan
« Last Edit: December 18, 2018, 02:46:58 pm by alanb »
Offline perieanuo
Re: Help needed to identify thermistor value in failed Avaya PSU
« Reply #1 on: December 18, 2018, 08:18:18 pm »
I'll have to check but view the code you're sure it's the PTC inrush?For me that code is the parallel varistor 275V that protect from over voltage
Envoyé de mon iPad en utilisant Tapatalk
The following users thanked this post: wraper
« Reply #2 on: December 18, 2018, 08:22:38 pm »
The code is correct but it is possible that I've wrongly traced how it is connected. I don't have the psu with me so I won't be able to check until tomorrow.
Offline perieanuo
« Reply #3 on: December 18, 2018, 10:12:08 pm »
http://www.produktinfo.conrad.com/datenblaetter/500000-524999/500592-da-01-en-Scheiben_Varistor_S10K275.pdf
Remove it and check the fuse and bridge and chopper transistor then power on.you had an voltage spike or some 380V on your ps
« Reply #4 on: December 19, 2018, 08:48:12 am »
Thank you Perieanuo, you are correct. It is the a Varistor for over voltage protection.
Unfortunately this is not the cause of the fault so I need to continue fault finding on this psu.
