Hi I have a soldron 878d soldering and rework station. Its one of those knock off of knock offs with a 936 style iron and a 8 pin hot air gun.
I have been happily using it since a year without any issue. Yesterday, while working with only iron, the hot air gun suddenly started blowing air at full speed like there's no tomorrow. Everything else works fine, the iron works nicely, the hot air element is heating up without issue, but I have lost speed control of the fan, it just goes at full speed all the time. Here is what I have tried so far:
1) Classic power cycle - didn't work
2) Open up the hot air gun, nothing looks funny
3) Open up the base station, checked the pcb, nothing is burnt, __However__, I found a rebellious 67k resistor who wandered too far. I have spent hours finding where it came from but no success. I'm thinking that is the culprit. The resistor seems to be broken, not burnt nor desoldered.
I would be grateful to you guys if you could help me solve this issue. If you have a similar model with similar pcb, can you please help me find this little resister's home?
Thanks
