Author Topic: Help needed with 2 resistors, Lafayette FET VOM  (Read 1229 times)
Offline Runco990Topic starter
« on: April 07, 2023, 09:33:54 pm »
So I picked up an "untested" Lafayette FET VOM from the bay.... where else.  I have stripped and cleaned it so far, it looks very nice.  Meter movement is perfect and it works.
However, it has 2 blown resistors.  a 2.27Kohm and a 29.5ohm both at 0.5% tolerance, looks like 1/4 watt.   I would like to avoid splicing resistors together to make the values, so does anyone have a lead?  I have looked and cannot find those values.  My "salvaged resistor" box does not have any.
It's kind of interesting and I had to rescue it.  I do like FET meters to align radios, so I do plan to use it.
Original listing pic.
Offline alm
Re: Help needed with 2 resistors, Lafayette FET VOM
« Reply #1 on: April 07, 2023, 10:14:52 pm »
I would just parallel resistors, like 2x59 Ohm for 29.5 Ohm, and 8.06 kOhm in parallel with 3.16 kOhm for 2.27 kOhm. They will fit neatly in the footprint of a single resistor. I know some manufacturers like Edwin Pettis and the Vishay Precision Group lets you order custom values in single quantities, but expect high prices and months long lead times.
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #2 on: April 08, 2023, 02:11:56 am »
Those resistors were likely custom made so it is not surprising you can't find them anywhere. The closest standard values are 2.26k \$\Omega\$ and 29.4 \$\Omega\$.
However, finding anyone who stocks these or is prepared to supply in small quantities might be frustrating. Using combinations of resistors might be the only option you have.
« Reply #3 on: April 08, 2023, 03:31:59 pm »
Man, you guys aren't kidding.  Finding anything IN STOCK is almost impossible these days.
Nothing so far on .5% resistors to even cobble something together.
Offline alm
« Reply #4 on: April 08, 2023, 03:49:46 pm »
Try looking for 0.1% resistors, they are more common, and in these quantities not that much more expensive. Mouser has 59 Ohm 0.5% in stock. I didn't check for the values to make 2.27 kOhm.
Offline JeremyC
« Reply #5 on: April 08, 2023, 03:53:13 pm »
You could use the 25 turns, 0.5W trimpots manufactured by Bourns.
Don't buy it from ebay, Alix, Amazon, etc. , but from trusted source like Mouser, DigiKey, etc.
Check the specs: https://www.mouser.com/datasheet/2/54/3296-776415.pdf
« Reply #6 on: April 08, 2023, 04:01:19 pm »
Thanks!  I was starting to think about that.  It's not super critical, being an analog meter.  I may just do that, even as a temp fix.  My primary use is really for peaking, and the handy "0" function.  And I just like interesting meters.   :-+
Offline alm
« Reply #7 on: April 08, 2023, 04:48:42 pm »
Be sure to put the pot in series with a much larger value fixed resistors, or a series/parallel combination so the pot only represents a small part of the total resistance. Trimpots are not the most stable things, especially under influence of vibration.
Online Wallace Gasiewicz
« Reply #8 on: April 09, 2023, 11:20:06 pm »
Perhaps if you have a bunch of 30 ohm 5% resistors look for one that is 29,5 ohms
Likewise maybe a 2.2 or 2.4 K ohm resistor might be found with a 2.27 ohm value.That is, if you have a good ohmeter that you trust.
Offline bdunham7
« Reply #9 on: April 09, 2023, 11:44:42 pm »
Vishay PTF562K2740BYEB  (Mouser does not have, you'd have to search)
TE Conn YR1B29R4CC (Mouser has)
If you can find those they should meet your value and tolerance requirements.  If you think they are overstressed and want to go a bit bigger to 1/2W, then
TE Conn H42K26BZA  (Mouser purportedly has them arriving in ~90 days)
TE Conn H429R4BYA  (not in stock anywhere AFAIK, but they might be in the reasonably near future as they are listed as a new product)
Additionally, if those can't be procured fast, easy and cheap, you can just get some 1% resistors in some nearby values than then try and select ones that are within your tolerances.  It's never easy, right?
« Reply #10 on: April 10, 2023, 12:06:42 am »
Nope.  But I am glad you were able to properly repair that Nixie meter you got from me.  I thought it was cool, but I can't keep EVERYTHING!
That op-amp was interesting.
