So, I've started a thread on badcaps (dunno if I can link it) about changing caps, but as some users posted the problem of one of those boards (the Tyan) may not lie on the caps themselves. The board is a Tyan S7012 (dual 1366 server-grade).
The symptoms the board is showing are the following:
* When I try to use 2x X5690 (130W TDP), the board power gets cut while in POST and it refuses to power up after it. I need to disconnect power, force a "power flush" (pressing the power on while PSU is disconnected) just for the whole thing to loop.
* I tested 2x E5649 (80W TDP). Installed Windows, did a lot of RAM testing (bootable memtest86+) and it work just fine on those basic tasks. When I tried to stress test the system with Prime95, I started hearing some "fshhh" noises, that remembered me of caps venting - but none of them are actually vented out on the top. I noticed that the mouse would freeze for a second or so sometimes, and the noise stopped while on this state. It didn't take long for the board to freeze completely (about 20 secs) and the noise to stop. Weird thing is that the board worked fine with those CPUs yesterday, even on the stress test.
* I remember testing the board with 2x 5504 (80W TDP but probably runs o a pretty low power) and the sizzling noise would be present while stress testing, but the board did hold up for the whole test.
* When I got this board I had some Intel coolers with a low bracket that ended up lifting one of the VRM's coils on one side. I turned the board on since it was unknown to me at the time - I found out about this a day later when I was swapping CPUs to test. I've resoldered it when I found out, but maybe some of the VRM ICs got toast? There isn't any smell, PCB discoloration or clear physical damage on them.
I'm using a EVGA 750BQ which is pretty new and was used to tested another server board with 2x X5690 and fully populated RAM, no problems at all.
I own a multimeter (Aneng 8009), soldering tools, a flash programmer (TL866II Plus) and lots of spare parts to test.
Could you please try to help me out? I'm kinda lost on where should I start.
