I have a Denon AVR-4520CI for repair. One Output transistor was shorted. I replaced both DHCT-C3 and DHCT-A3. Both pair of .22 ohm emiter resistors are okay. Before I returned the Amp Board to the receiver, I tested both the DHCT-C3 and the DHCT-A3 with a semiconductor analyzer against another pair in one of the good Amp Boards. The DHCT-C3 and the DHCT-A3 that I replaced shows a collector leakage Icbo of 4.7 ua versis 1.3 ua on the other boards. I have attached the schematic (FHL board). Could anyone tell me why I have 3.5x higher leakage? The other resistors and transistors check okay in circuit. Could D506 be the problem?
Thank you,
Chuck
